nano is on but wheel function not working
My nano is fully charged and on but the wheel is not wroking. I press on menu or play and nothing happens. I tried to reset it by holding down the menu and select buttun but it did npot work
Это хороший вопрос?
Оценка 1
Добавить комментарий
4 Ответов
Наиболее полезный ответ
First try restoring it on iTunes. but if that doesn't work, it's very probably it is bad hardware. Try replacing the clickwheel (and headphone jack/case assembly) but if that doesn't do it, it's a bad motherboard.
Был ли этот ответ полезен?
Оценка 2
screen unlock system rebooting and taking off the code.
Оценка 0
1 Комментарий:
Would you mind putting this into a complete sentence?
из
Repair on my screenlock chromatic code 2generation code.
Оценка 0
1 Комментарий:
Would you mind putting this into a complete sentence? Instead of starting a new answer please just comment under your first one.
из
I had my 2nd gen nano, which I locked up on me. I used to workout with it and think it was moisture that caused it to seize. I put it aside in my closet and didn't touch it for a year. I fired it up just recently and it works as good as new. If this happens to any of you I recommend trying to demoisturize it by buying some silica and putting it in a ziploc bag.
Good luck
Оценка 0
Добавьте свой ответ
fran будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 6,071
