Are Pre-installed OSX available on new SSD?
I would like to replace my damaged hard drive on my Mac mini late 2014. Could I get a SSD with The OSX pre-installed, is that possible?
Это хороший вопрос?
Это хороший вопрос?
As @vladaad stated drives don’t come with the OS installed you need to install it your self.
There are a couple of ways to install a fresh OS with very little effort! If you have a good internet connection you can install the OS via Internet recovery just by connecting your system to either a WiFi or Ethernet connection.
If you have access to a second system you can setup your Mac Mini in Target Disk Mode and using a Thunderbolt cable between the two systems you can use the other Mac OS installer to install the OS onto your Mini.
Another way is to get a USB thumb drive and set it up on the other Mac or before you remove your current drive set it up as an OS installer.
So how do I do all of these different ways? Here you go!
Internet Recovery - Restart your system and press Command (⌘) and R keys
Target Disk Mode - Restart your Mac Mini system and press T key, then connect your other system to yours via Thunderbolt Cable.
Setup a bootable OS installer follow this guide How to create a bootable macOS Mojave installer drive
And here’s how to get the best macOS for your system How to upgrade to macOS Mojave (jump down to Step 4 for the direct link) Use this OS for either method.
References:
Был ли этот ответ полезен?
You can’t buy an SSD with an OS preinstalled. You have to install it yourself from a USB Drive.
За последние 24 час(ов): 2
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 588
