The battery connection on motherboard broke, is this fixable?
I have an asus zepherous g laptop that shut off immediatly when I unplugged the laptop. I opened it to check and saw that the battery connection to the motherboard was completely torn off, is there any way that someone can fix this?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
This can be easily fixed by someone who is capable at soldering. Any computer repair shop should be able to do it for a minor fee. I had a similar repair done for $40. If you are not experienced at soldering and microsoldering then do not try to fix this yourself.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
spots onesevenseven будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 150
