{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
Gradiant dark shade in bottom of screen, doing video editing
When doing some video editing, or working on the machine for a longer time, I get this line running across the sceen
Could it be a graphics card issue? Screen issue?
Anybody experienced similar?
Это хороший вопрос?
Оценка 0
1 Комментарий
Thank you for sharing.
из
Добавить комментарий
Ответов (1)
Выбранное решение
Sadly you’ve hit a known issue that has plagued a lot of people ;-{
And there are a others!
If you are lucky you haven’t permanently damaged the T-CON board. Make sure your systems vents are not blocked and you may want to dust out the system if you think it’s dirty. I would install a good thermal management app like TG Pro and pumping up the fans when you are pressing your system hard.
If that doesn’t help its time for a new display assembly - Ouch!
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks for the indepth answer. Changed the screen
из
Добавьте свой ответ
Sonnicham будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 170
