This is a touch-screen controller associated with the Wii U video game console. It was released on November 18th, 2012, and available in black or white. Model number: WUP-010(USA)
83вопросов Показать все
Blue power light fading out
I bought a cheap Wii u gamepad for parts to try and fix it. The blue power light fades away once you hit the power button and when it's plugged into a charger, the charge light comes on and stays on when you unplug it. I replaced the battery and nothing changed. What causes this issue
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
It’s possible there is a motherboard inside the game pad similar to the PSP. It will control the lights on the side of the pad.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
it does but would a bad screen cause the fading blue power light
из
Добавьте свой ответ
Cheap gamer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 16
За всё время: 574
