Lid making grinding noise when I close it
Hello,
I have some sort of an issue with my MacBook pro 2019. Whenever I open the lid above 90 degrees, and when I close it, it makes kind of a grind noise as something is touching inside between the lid and the antenna.
This is the noise that is making.
What is your opinion about this stuff? Did you seen or heard anything like this?
Thank you
Это хороший вопрос?
Did you bang the system or have something sit on it?
Something is bent or out of alignment!
из Dan
No, it,s just out of the box brand new, no hits . Everything seems ok with it execept with this thing. I will try to remove the back cover to see whats up but i can't find a pentalobe screw
из cvld88
