Updated version of the 2016 Retina MacBook. Model A1534, EMC 3099. Now features faster Kaby Lake processors up to 1.4 GHz Core i7 with Turbo Boost up to 3.6 GHz and up to 50 percent faster SSD, and supports up to twice the memory.
82вопросов Показать все
Does not boot, black screen, no caps-lock light
MacBook has recently stopped booting, no liquid or impact damage. The trackpad is clickable however the screen remains black and the caps-lock does not light when tapped some minutes after boot. The CPU heats up. Interestingly when connected to another MacBook (Pro) by USB-C (for example to attempt target disk mode) the trackpad is no longer clickable.
I’ve swapped out the uppercase and display to a spare to see if it’s an issue there along with disconnecting the keyboard but the issue persists which suggests to me it’s an issue with the logic board.
Anyone have experience of this before and what might have gone wrong on the logic board?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
What does an external monitor show you (TB3 to HDMI dongle)? If it doesn’t show anything then the logic board has failed.
Update (05/05/2020)
You’ll need to find someone which has the skills to diagnose what has failed on your logic board or just replace it! MacBook 12" Retina (2017) 1.2 GHz Logic Board. Here’s the guide to replace it Retina MacBook 2017 Logic Board Replacement
MacBook 12" Retina (2017) 1.2 GHz Logic Board Изображение
Продукт
$349.99
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Nothing on an external monitor.
из
Добавьте свой ответ
jgarnham будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 320
