Macbpro freezes, fans go to overdrive
Hey guys, I looked for an answer to my problem in related branches, haven’t found what I needed.
I have an old mac book pro (it’s a 2.53 one) and it worked well until it stopped, which happened about 1/2 year ago (maybe after I dropped on the floor, maybe) - it randomly freezes with its fans going to max speed within about a minute of that happening (unless they were already at max speed). It doesn't respond to anything so I have to force shut it, by pressing the turn on/off button for 3 seconds.
I tried reinstalling the os - Yosemite on my origial HDD. Bought and installed a new SSD. Tried yosemite, then changed the os from yosemite to high sierra on the new ssd. Then, added 4gb memory (now it has 8). I cleaned the fans and the area around them. None of those things helped. I understand it's not great to shut it off the way I do, but i don't have many options + I keep the new main SSD empty, so maybe a little less damage.
I have a CPU monitoring tab open and notice that it can be full (ie nearly 100% loaded) and still working fine. When it freezes the tab is usually nowhere near 100% (obviously, once it freezes it can't show me a sudden jump). Normally the laptop is hot when it freezes, but again, it can be really hot and still working. If I restart it a minute after shutting it off it can freeze again rather fast. If I let it sit for a bit that can usually delay the problem. Only once did I get an error log on boot up - I pasted it at the end of my message.
Change your mac is perhaps an option BUT I feel like this one still does the job, it's perfectly fine for surfing. With 6 hundred something score on geekbench it's only half as good as some of 3-4 year old airs. And I had it for almost half my life -12 years, I'm 26, so it really means something to me. Why waste money on a laptop that I will hardly utilise to its fullest?
What could be the cause of this problem? I would really appreciate any help.
Kind regards,
Mike
Anonymous UUID: B6A63C7C-68B3-D427-CDB7-44E7EB329180
Mon Mar 2 18:54:10 2020
- Panic Report ***
Machine-check capabilities: 0x0000000000000806
family: 6 model: 23 stepping: 6 microcode: 1551
signature: 0x10676
Intel(R) Core(TM)2 Duo CPU T9400 @ 2.53GHz
6 error-reporting banks
Processor 0: IA32_MCG_STATUS: 0x0000000000000004
IA32_MC0_STATUS(0x401): 0xb600040004900800
IA32_MC0_ADDR(0x402): 0x00000000d4070000
IA32_MC5_STATUS(0x415): 0xb200001044100e0f
Processor 1: IA32_MCG_STATUS: 0x0000000000000004
IA32_MC5_STATUS(0x415): 0xb200001040100e0f
mp_kdp_enter(): 1, 1, 2 TIMED-OUT WAITING FOR NMI-ACK, PROCEEDING
panic(cpu 1 caller 0xffffff800978811a): "Machine Check at 0x00007fff3d7b9c51, registers:\n" "CR0: 0x0000000080010033, CR2: 0x00007fb454055008, CR3: 0x000000001dfec000, CR4: 0x00000000000026e0\n" "RAX: 0x00007fff929b7568, RBX: 0x0000600000239020, RCX: 0x00007fff8d9e8560, RDX: 0x0000600000239028\n" "RSP: 0x00007ffeebcdc140, RBP: 0x00007ffeebcdc140, RSI: 0x00007fff30654003, RDI: 0x0000600000239020\n" "R8: 0x00006040002366a0, R9: 0x00007fff8c3b58a0, R10: 0x00007fff8d9e8560, R11: 0x00007fb06e196030\n" "R12: 0x00007fff596f5150, R13: 0x00007fb06d5722b0, R14: 0x00007fff596f2e80, R15: 0x0000000104142d21\n" "RFL: 0x0000000000010246, RIP: 0x00007fff3d7b9c51, CS: 0x000000000000002b, SS: 0x0000000000000023\n" "Error code: 0x0000000000000000\n"@/BuildRoot/Library/Caches/com.apple.xbs/Sources/xnu/xnu-4570.71.2/osfmk/i386/trap_native.c:168
Backtrace (CPU 1), Frame : Return Address
0xffffff8112413c00 : 0xffffff800966c1c6
0xffffff8112413c50 : 0xffffff8009795274
0xffffff8112413c90 : 0xffffff8009787544
0xffffff8112413d00 : 0xffffff800961e1e0
0xffffff8112413d20 : 0xffffff800966bc3c
0xffffff8112413e50 : 0xffffff800966b9fc
0xffffff8112413eb0 : 0xffffff800978811a
0xffffff8112413fa0 : 0xffffff800961ea5f
BSD process name corresponding to current thread: Be Focused
Boot args: -no_compat_check
Mac OS version:
17G66
Kernel version:
Darwin Kernel Version 17.7.0: Thu Jun 21 22:53:14 PDT 2018; root:xnu-4570.71.2~1/RELEASE_X86_64
Kernel UUID: 1AE5ACFD-3B6F-3D74-AD52-31F1430DBC6F
Kernel slide: 0x0000000009400000
Kernel text base: 0xffffff8009600000
__HIB text base: 0xffffff8009500000
System model name: MacBookPro5,1 (Mac-F42D86C8)
System uptime in nanoseconds: 32704979653458
last loaded kext at 25964570861415: com.apple.filesystems.smbfs 3.2.3 (addr 0xffffff7f8c6a3000, size 434176)
last unloaded kext at 994789480221: com.apple.driver.AppleUSBMergeNub 900.4.1 (addr 0xffffff7f8ae5d000, size 12288)
loaded kexts:
com.parrotgeek.SIPManager 1
com.apple.driver.AudioAUUC 1.70
com.apple.driver.AppleHWSensor 1.9.5d0
com.apple.filesystems.autofs 3.0
com.apple.driver.AGPM 110.23.37
com.apple.driver.AppleMikeyHIDDriver 131
com.apple.driver.AppleHDA 281.52
com.apple.AGDCPluginDisplayMetrics 3.20.13
com.apple.driver.pmtelemetry 1
com.apple.iokit.IOUserEthernet 1.0.1
com.apple.driver.AppleMikeyDriver 281.52
com.apple.iokit.IOBluetoothSerialManager 6.0.7f10
com.apple.driver.AppleSMCLMU 211
com.apple.driver.AppleUpstreamUserClient 3.6.5
com.apple.driver.ACPI_SMC_PlatformPlugin 1.0.0
com.apple.driver.AppleOSXWatchdog 1
com.apple.driver.AppleMuxControl 3.20.13
com.apple.GeForceTesla 10.0.4
com.apple.driver.AppleLPC 3.1
com.apple.Dont_Steal_Mac_OS_X 7.0.0
com.apple.driver.AppleHV 1
com.apple.driver.AppleIntelSlowAdaptiveClocking 4.0.0
com.apple.driver.AGDCBacklightControl 3.20.13
com.apple.driver.AppleMCCSControl 1.5.5
com.apple.driver.SMCMotionSensor 3.0.4d1
com.apple.driver.AppleUSBTCButtons 254
com.apple.driver.AppleUSBTCKeyboard 254
com.apple.driver.AppleIRController 353
com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 1.0.0d1
com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 1.0.0
com.apple.AppleSystemPolicy 1.0
com.apple.BootCache 40
com.apple.filesystems.hfs.kext 407.50.6
com.apple.driver.AppleAHCIPort 329.50.2
com.apple.driver.AirPort.Brcm4331 800.21.30
com.apple.nvenet 2.0.22
com.apple.driver.AppleFWOHCI 5.5.9
com.apple.driver.AppleSmartBatteryManager 161.0.0
com.apple.driver.AppleRTC 2.0
com.apple.driver.AppleHPET 1.8
com.apple.driver.AppleACPIButtons 6.1
com.apple.driver.AppleSMBIOS 2.1
com.apple.driver.AppleACPIEC 6.1
com.apple.driver.AppleAPIC 1.7
com.apple.driver.AppleIntelCPUPowerManagementClient 220.50.1
com.apple.nke.applicationfirewall 183
com.apple.security.quarantine 3
com.apple.security.TMSafetyNet 8
com.apple.driver.AppleIntelCPUPowerManagement 220.50.1
com.apple.kext.triggers 1.0
com.apple.driver.DspFuncLib 281.52
com.apple.kext.OSvKernDSPLib 526
com.apple.iokit.IOSurface 211.15
com.apple.iokit.IOSerialFamily 11
com.apple.iokit.IOAVBFamily 680.2
com.apple.plugin.IOgPTPPlugin 680.15
com.apple.iokit.IOEthernetAVBController 1.1.0
com.apple.driver.IOPlatformPluginLegacy 1.0.0
com.apple.driver.AppleSMBusPCI 1.0.14d1
com.apple.iokit.IOFireWireIP 2.2.9
com.apple.driver.AppleGraphicsControl 3.20.13
com.apple.nvidia.classic.NVDANV50HalTesla 10.0.4
com.apple.nvidia.classic.NVDAResmanTesla 10.0.4
com.apple.driver.AppleHDAController 281.52
com.apple.iokit.IOHDAFamily 281.52
com.apple.iokit.IOAudioFamily 206.5
com.apple.vecLib.kext 1.2.0
com.apple.driver.IOPlatformPluginFamily 6.0.0d8
com.apple.driver.AppleSSE 1.0
com.apple.AppleGPUWrangler 3.20.13
com.apple.iokit.IOSlowAdaptiveClockingFamily 1.0.0
com.apple.AppleGraphicsDeviceControl 3.20.13
com.apple.driver.AppleBacklightExpert 1.1.0
com.apple.driver.AppleSMBusController 1.0.18d1
com.apple.iokit.IONDRVSupport 519.20
com.apple.iokit.IOGraphicsFamily 519.20
com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport 6.0.7f10
com.apple.iokit.IOBluetoothHostControllerUSBTransport 6.0.7f10
com.apple.iokit.IOBluetoothHostControllerTransport 6.0.7f10
com.apple.iokit.IOBluetoothFamily 6.0.7f10
com.apple.driver.AppleUSBMultitouch 262
com.apple.driver.usb.AppleUSBHub 1.2
com.apple.driver.usb.IOUSBHostHIDDevice 1.2
com.apple.driver.usb.networking 5.0.0
com.apple.driver.usb.AppleUSBHostCompositeDevice 1.2
com.apple.filesystems.hfs.encodings.kext 1
com.apple.iokit.IOAHCIBlockStorage 301.40.2
com.apple.iokit.IOAHCIFamily 288
com.apple.iokit.IO80211Family 1200.12.2
com.apple.driver.corecapture 1.0.4
com.apple.iokit.IOFireWireFamily 4.7.2
com.apple.driver.usb.AppleUSBEHCIPCI 1.2
com.apple.driver.usb.AppleUSBOHCIPCI 1.2
com.apple.driver.usb.AppleUSBOHCI 1.2
com.apple.driver.usb.AppleUSBEHCI 1.2
com.apple.driver.NVSMU 2.2.9
com.apple.driver.usb.AppleUSBHostPacketFilter 1.0
com.apple.iokit.IOUSBFamily 900.4.1
com.apple.driver.AppleEFINVRAM 2.1
com.apple.driver.AppleEFIRuntime 2.1
com.apple.driver.AppleUSBHostMergeProperties 1.2
com.apple.iokit.IOSMBusFamily 1.1
com.apple.iokit.IOHIDFamily 2.0.0
com.apple.security.sandbox 300.0
com.apple.kext.AppleMatch 1.0.0d1
com.apple.driver.AppleFDEKeyStore 28.30
com.apple.driver.AppleEffaceableStorage 1.0
com.apple.driver.AppleKeyStore 2
com.apple.driver.AppleUSBTDM 439.70.3
com.apple.driver.AppleMobileFileIntegrity 1.0.5
com.apple.iokit.IOUSBMassStorageDriver 140.70.2
com.apple.iokit.IOSCSIBlockCommandsDevice 404.30.2
com.apple.iokit.IOSCSIArchitectureModelFamily 404.30.2
com.apple.driver.AppleCredentialManager 1.0
com.apple.driver.KernelRelayHost 1
com.apple.iokit.IOUSBHostFamily 1.2
com.apple.driver.usb.AppleUSBCommon 1.0
com.apple.driver.AppleBusPowerController 1.0
com.apple.driver.AppleSEPManager 1.0.1
com.apple.driver.IOSlaveProcessor 1
com.apple.driver.DiskImages 480.60.1
com.apple.iokit.IOStorageFamily 2.1
com.apple.iokit.IOReportFamily 31
com.apple.iokit.IOTimeSyncFamily 680.15
com.apple.iokit.IONetworkingFamily 3.4
com.apple.driver.AppleACPIPlatform 6.1
com.apple.driver.AppleSMC 3.1.9
com.apple.iokit.IOPCIFamily 2.9
com.apple.iokit.IOACPIFamily 1.4
com.apple.kec.Libm 1
com.apple.kec.pthread 1
com.apple.kec.corecrypto 1.0
EOF
Model: MacBookPro5,1, BootROM MBP51.007E.B06, 2 processors, Intel Core 2 Duo, 2,53 GHz, 8 GB, SMC 1.33f8
Graphics: NVIDIA GeForce 9400M, NVIDIA GeForce 9400M
Graphics: NVIDIA GeForce 9600M GT, NVIDIA GeForce 9600M GT, PCIe
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353237334248312D4346382020
Memory Module: BANK 0/DIMM1, 4 GB, DDR3, 1067 MHz, 0x80CE, 0x4D34373142353237334248312D4346382020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8D), Broadcom BCM43xx 1.0 (5.106.98.102.30)
Bluetooth: Version 6.0.7f10, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: WDC WDS240G2G0A-00JH30, 240,07 GB
Serial ATA Device: WDC WD5000LPLX-22ZNTT0, 500,11 GB
USB Device: USB Bus
USB Device: Apple Internal Keyboard / Trackpad
USB Device: IR Receiver
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 2.0 Bus
USB Device: Built-in iSight
Thunderbolt Bus:
Это хороший вопрос?
