My MacBookpro 17 (2006) inch has broken charging circuit?
Hi, after a while I’ve pulled my old mac book pro 17” core duo 2006 from wardrobe and when plugged I can hear something spinning like hdd but no boot chime: long story short I removed main battery (and also small cr2320 clock battery) the computer boot when cable is plugged but to completely turn it off I need to unplug the cable: reboot command don’t work, even when long pressing power button (after shutdown) can hear hdd spin down (I think) but unable to power it up again.
I read on this forum that drained batteries can cause these symptoms and I left the battery in charge for few hours but it remains almost at zero charge but computer get hot on rear near screen hinge, battery still quite cool .
Two temperature sensors read negative value:
TB0T: -128.0°C
Ts1P: -128.0°C
I can’t test the battery itself but the fact that computer can’t power off and on again without unplugging current cable suggest me another source of the problem.
Replace the MagSafe DC-IN Audio Jack USB Board could worth a try (on ebay for 9$ + shipping)?
Thanks!
Это хороший вопрос?
Счет 0
Добавить комментарий
