I lost my serial number after replace the logic board
I change the logic board of the mbp from other one (serial number working properly), but now the serial number is “Unavailable”. What i should do?
Это хороший вопрос?
Счет 0
1 Комментарий:
Can you explain a bit more on what you did here. Did you just swap the boards out? If you did then you'll need to go to the seller of the board to get it exchanged.
из
Добавить комментарий
