This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316вопросов Показать все
Touchscreen not working after plastic cover replacement?
I am just getting into fixing broken ds lites. I replaced the touchscreen and it worked great till i realized the plastic cover for the touchscreen was a different color. When I replaced the plastic cover the touchscreen no longer works. What did I do wrong?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
So apparently the to what I can gather the D.S. Lite’s touch screen is a resistive touchscreen made of two sheets. When removing the plastic overlay the top sheet often comes off essentially destroying the touchscreen. Be careful not to remove that layer if you are going to be taking off the plastic frame.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
i assume that layer is the one who receive all the scratches... there is any way to replace it? does it have a special name? so if i stick the frame directly to the touchscreen it won't work ,isn't it?
из
Добавьте свой ответ
Bradley Trietsch будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 780
