Discs spin and don’t read
Hi,
I recently replaced a faulty lens in my PS3 slim, and the discs still are not playing. Neither cds/DVD’s nor Blu ray will play. The discs spin a couple times, the screen shows the “spooling” image up in the corner, but after a few attempts stops without working.
What are the next steps to try? The previous laser (the on I replaced) would read cd/DVDs but not Blu-ray, which is why I replaced it.
I also replaced the 45-pin cable, which had a burnt spot on it. Is it possible I put the cable in incorrectly? Can the drive even function if the cable is not properly installed? I matched the alignment to the old cable, so I’m pretty sure that’s not the problem.
I don’t want to change the alignment of the cable in case it causes some kind of short. What are my options here?
Это хороший вопрос?
you need to clean the lens with a microfiber cloth
из Jacob Salazar
