Repair, support, and service information for thermal cyclers. Also referred as a PCR machine or DNA amplifier.
Вопросов 3 Показать все
Support of Bio-Rad S1000 PCR
The S/n under 10,000 is no longer supported can you guys work on these?
Это хороший вопрос?
Оценка 0
1 Комментарий:
I have a problem, I was using two PCR (C1000 Touch thermal cycler) at the same time because I'm having many samples, unfortunately, all of them stopped working, and when I switch them on it only ended with SYSTEM INITIALIZATION on the screen.
Can anyone help me how to fix this problem?
Gregory
из
Добавить комментарий
Ответов (1)
Hi Chad,
I had at least couple of these with 1 (that is ONE) faulty capacitor in power supply that manufacturer solution was not to repair but to supply whole board. If your PCR machine doesn’t power on or shuts off occasionally, could be that capacitor C19 100uF has to be replaced. Hopefully you can find someone to do that for you. Make sure that backup battery on the board is NEVER REMOVED!!! because you will loose firmware data and machine will become unusable. If you have problem with the block then i’m afraid there wont be much you can do.
All the best
John
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
how to connect s1000 bio rad thermal cycler to computer?
из
Добавьте свой ответ
chad richardson будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 6
За последние 30 дней: 13
За всё время: 688
