MacBook Pro 15" Mid 2010 Airport card upgrade to early 2011 card?
I have a Macbook Pro 15" Unibody Mid 2010 that was dropped. I have replaced most of the parts, but I can't find an antenna for the airport card.
I have found an antenna for an Early 2011 Macbook Pro 15". In the teardown guides, all of the wireless parts look like they could be swapped out.
Does anyone know if it is possible to upgrade my Mid-2010 airport system to the newer Early-2011 airport system?
Thanks,
Chris
Update (04/21/2016)
I found an antenna on eBay. I did not choose to upgrade the card or antennas.
Это хороший вопрос?
Оценка 2
8 Комментариев
Did it work?
Please let us know.
из
Also interested in knowing if this worked. I want to get Bluetooth 4.0 on my 2010 MBP as well.
из
You can. Just installed a BT LE card on mine. However it requires a few modifications. 1: cut out new holes for the plastic container or order the 2013 part. 2: connect the wifi plug to J0 and J1 (there is no cable for J3) 3: the cable that goes to the MB is a bit to long. (no fix really)
из
Any pictures or a walkthrough on that. I think a lot of people will want to upgrade to 4.0 to get continuity in OSX Yosemite.
из
continuity still not available.. Looks like a new machine is the only option if you want the new feature. This is so Apple
из
Показать 3 больше комментариев
Добавить комментарий
2 Ответов
Выбранное решение
It seems like the MacBook Pro 15" and 17" Unibody (Mid 2010) Airport/Bluetooth Board is different from the 2011 model. The connection looks like its the same but the placement is different which could cause the cable to be too short or too long.
Maybe it's worth a try? It won't be a snug fit though.
MacBook Pro 15" and 17" Unibody (Mid 2010) Airport/Bluetooth Board Изображение
Продукт
$29.99
MacBook Pro Unibody (Early 2011-Mid 2012) AirPort/Bluetooth Board Изображение
Продукт
$42.99
Был ли этот ответ полезен?
Оценка 6
1 Комментарий:
I have a Mid 2010 15" and am changing the logic board to a Late 2011. My BT/Wifi board is working fine. And the cable to the logic board seems to fit fine. I just wonder if I really will just work or if I have to have a 2011 BT/Wifi board. Any experience?
из
Оценка 0
2 Комментариев:
Better yet, you can use this tool if you have a BT 4/LE board in the system: Continuity Activation Tool
из
Добавьте свой ответ
Chris будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 11
За всё время: 8,762
