Table lamps are designed to sit on tables. They are not floor lamps, which sit on the floor. Table lamps are usually shorter than floor lamps.
Bedside LED Lamp turns on and then off in a blink
Hello everyone.
Here is my bedside lamp which has some problems, when I turn it on, it turns on just for a moment and then goes off. Which component in its circuit is probably causing this? Is it one of those 3 LEDs or that capacitor or one of those resistors?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Wow , the soldering looks bad.
Did you did anything?
Do you have a multimeter?
If so, since it has minimal components, you can actually test quick,
test the LED
Test the resistance of the resistor.
Looking at the LED, i doubt it is bad, it seems that there are bad solder in place.
I would suggest you to resolder those cold / bad solder joints first.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Erfan Monemi буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 298
