The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
159вопросов Показать все
Regular x and scorpio edt. Not turning on.
Hey guys. I work in online retail in the returns. We've got back a few 1 x, and 1 x scorpios that refuse to power on. Most common is to here the chime, light comes on but light goes right back off and nothing happens. I have attempted to swap power supply's once to no avail. Anything concrete I should know about?
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Hi Jermy!
Someone else had the same issue as you: The power of my Xbox one x flashes then shuts off
My guess was the power supply too.. But you already replaced the power supply. So this should be good.
What more to test:
  • Harddrive
  • Wifi board
  • Bluetooth board
  • Last thing: Check the motherboard and meassure if possible
You have another Xbox X (which works) there, right? Just try to swap parts out and you’ll see what part is causing it. I know it sounds kinda lame, but there are a lot of parts which can cause the xbox not to boot due errors.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Jermy Tee будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 328
