Full Size Sedan sold to Police in North America as the Chevrolet Caprice Police Patrol Vehicle
3вопросов Показать все
How to fix my rear bumper?
Hi All,
Just wondering how I can fix my rear bumper.. What kind of materials/tools do I need? Or is it better to replace the rear bumper entirely? If yes, is there an manual for how to do it? (just wondering if there are any hidden screws)
It’s a 2017 Chevrolet Camaro (not the Caprice, was unable to select the Camaro).
If a picture is required, please let me know.
Это хороший вопрос?
Оценка 0
4 Комментариев
Can you put pictures up please
из
@barriphone Picture is attached!
из
موقع زي الزفت
из
ما منو فايده
из
Добавить комментарий
1 ответ
Выбранное решение
It looks like something punched a slot in it and it's cracked on the top. I am not a body man but I have heard it being done with bondo and a flexible additive. I would would check into that. You don't need to replace the bumper. That would be expensive and you can either blend in the paint for those two areas or for a better result paint the entire bumper. It's hard to blend clear coat but if you do the whole number and it won't be noticed because of the seam between panels.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks for your answer! Yeah it was already there and now it's the time I want to get it fixed :). Did some research and found something like this: https://www.walmart.com/ip/3M-Bondo-Stag...
Should that be enough? First I'll try to use the Bondo kit, otherwise I could paint it afterwards.
Thanks!
из
Добавьте свой ответ
koppie007 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 19
За всё время: 271
