Guides and support for various television (TV) brands and styles.
9064вопросов Показать все
TV suddenly black screen, no audio
My TV suddenly dark screen ?! I unplugged , then plug back , it still black screen, no audio , the remote only able to turn on , it can not turn off . The screen is completely dark. How to fix it?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
dong diana that depends on the make and exact model of your TV. It is possible that this is a power board issue or a main board issue. Once you give us more details about the make and exact model for your TV we can hopefully narrow it down for you. Let us know if your power LED is on or if your TV shows any sign of life.  If not you will have to remove the back cover from your TV and check a few things (power board/ main board) out. Again, we need make and model to try and help you out further
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
dong diana будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 41
