2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274вопросов Показать все
Can I replace/upgrade the logic board on my 15" MBP Retina Early 2013?
The logic board on my 15” MP Retina Early 2013 model (Intel i7 Processor with 512 GB SSD, 16GB RAM, 1GB NVIDIA Card) is not working properly - the sound ports have no output and the Display just switches off while I am working even though the machine is still turned on; making it impossible for me to do any work. I can’t really afford a new laptop either in my current scenario and hence want to get this issue resolved as I was informed that the issue is a Logic Board issue and that the local service centers in India don’t have spares of these.
I would like to know if it possible to replace/upgrade the logic board and also where can I source the replacement logic board from? Any guidance would be much appreciated. Thank you for your time.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Yes! You can replace your logic board following this guide MacBook Pro 15" Retina Display Early 2013 Logic Board Replacement
But I’ll warn you! Replacement logic boards are not cheap! And more so in India (import taxes)!! The problem is these systems are still very popular! So parts are not readily available as such they go for a premium price.
I would recommend you look for someone in India that has the skills to fix yours as that would be cheaper!
Anyways here’s one option: https://www.thebookyard.com/parts-retina...
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Praveen Venugopal будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 81
