Peavey VYPYR VIP 1 does not turn on.
The amp was 110v so i plugged it to 220v.
I changed the fuse but it didn't work. I noticed something strange about the power supply heatsink. What are the next steps to find the cause of the problem?
Это хороший вопрос?
1 Комментарий
@weqs ... according to your board, if you fix the issue that the 220v on a 110v caused, you can re wire the system to be rated at 220v. look at the power supply board next to the ac adapter. printed right there on the board. will need the proper components and research to do so. good luck.
из jostewcrew
