The LG VX440 is a CDMA phone with a dual display and an extendable antenna.
Вопрос закрыт
How do I unsilence my phone?
I have an old vx4400 phone. The ringer remains on silent. I've adjusted all sounds to high volume and the rocker switch has been rocked all the way up. The phone vibrates but does not ring. The screen says its on 'silence all.' What am I missing?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
sara sabeha, since you already tried all the buttons, and if there is not physical damage to the phone, I would see if you have your "manner mode" engaged. This mode will set your phone pretty much in silent. Here are the instructions from the manual which is available right here
" Using Manner, Silence All, Lock Mode
Manner Mode (Quick)
Use Manner Mode in a public place.
1. In Standby Mode, activate Manner Mode quickly by pressing
(for 3 seconds) instead of using the Menu function.
- When the cellcase is closed, Manner Mode can be activated by pressing and holding the Voice Memo Key. G When Manner Mode is set, Manner Mode( ) is displayed on the LCD screen.
G When Manner Mode is set, key tone does not sound and Vibration is selected as the ringer.
NOTE Selecting Manner Mode will allow you to maintain your phone under Manner Mode even when you turn it off and turn it back on.
NOTE To cancel Manner Mode, press again until Silence All activated! is displayed and press again until Normal Mode activated is displayed. By the way, here is the picture for you to identify which key it is :-) Good Luck and I hope this helps.
Был ли этот ответ полезен?
Оценка 2
i think you just need to hold the '#' button to make it silent and make it normal.
Оценка 1
3 Комментариев:
Larry the # key will unlock it and the * key is the Manner Mode key, so you are right about the key ;-) if you need to unlock the keypad first...
из
oh yeah. you're right =). its the '*' key.
из
still a very valid answer ;-)
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 5,579
