Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
1 inch from left side not responding after installing new digitizer
i installed a new touch screen digitizer and for some reason about 1 inch from the left side of the screen there is no touch response at all is there a fix to this ? i bought a zentop digitizer for my a1822 ipad
Это хороший вопрос?
Счет 0
1 Комментарий:
This is my second screen that has had this issue my connectors look fine. Can it be the screens im getting are bad? Should i try the ifix it brand of digitizers?
из
Добавить комментарий
2 Ответов
It sounds like you have a defective part.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
This is most likely the case. OP try reseating the digitiser connectors on the board and see if that helps.
The other thing to note is that there is a peel for the adhesive on the digitiser cable that sticks that cable to the glass like the original screen has.
из
Same product, same problem here
Счет 0
Добавьте свой ответ
pat буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 113
