Jura F50 water blockage
Water is not flowing through the coffee
Update (06/27/20)
Jura F50. Water is not going through the coffee. Hence no cups of fresh coffee. What could be blocking the water flow?
Это хороший вопрос?
Это хороший вопрос?
Open it and look for the clogging. There are different possibilities: heater calcified, brewing unit, drainage valve, the pump (can you hear it working?)
Инструкция
Сложность:
Легко
5 - 10 minutes
Инструкция
Сложность:
Модерировать
1 hour
Инструкция
Сложность:
Модерировать
9 - 15 minutes
Был ли этот ответ полезен?
I had the same problem. It was basically the gasket in the bottom of the water tank that needed to be replaced after 12 years. I bought a new water tank for 50 EUR and it was solved.
It's much cheaper just to replace the gasket or the valve of the tank.
За последние 24часов: 4
За последние 7 дней: 16
За последние 30 дней: 53
За всё время: 1,901
