Kernel_task 300% and fans on full
Hi, So I recently started reusing my old iMac after a couple years of not using it, I’ve been using it only in target display mode for my 2017 MacBook Pro via a thunderbolt cable and adapter and when I started the iMac up today the fans were on full and Activity monitor showed kernel_task reaching very high CPU levels, highest I’ve seen the kernel_task was at 495% today. As a result of course everything is extremely slow at the moment and it won’t enter target display mode either. I installed iStats menu to look at the temperature sensors, pictured below, I can’t seem to find anything abnormal and the CPU doesn’t seem hot from what I can tell, the fans are still going crazy though. I’ve already rest SMC, booted in safe mode, resetted PRAM but all to no avail. Apple Hardware testing won’t work - I just get an error message saying “Error: 0x800000etc, Cannot Load "EFI/Drivers/TestSupport.efi". So I’m kind of stumped as to what to do next, I’d rather not have to take it in to an Apple Store, especially at the moment.
Это хороший вопрос?
You'll need to run the onboard diagnostics to see if you get an error code. let us know what you get!
Restart your system and press the D key
Reference: Mac startup key combinations
из Dan
@danj Can't seem to get the onboard diagnostics to work, have tried multiple times but all I get is a black screen with:
"Error: 0x8000000000000003, Cannot Load 'EFI/Drivers/TestSupport.efi'
Status: 0x00000003"
из M S
Sadly you hit an Apple bug in the newer firmware ;-{
Let's see if the paid version of TG Pro gets a better data point.
Without knowing where to focus its a crapshoot on which sensor is firing off.
из Dan
