Gaming laptop released in 2014 with an Nvidia 860M graphics card and a 15.6" display. Updated in 2015 with 960M graphics.
40вопросов Показать все
Lenvo Y50-70 Charging Port wiring on mother board
Hi,
My lenovo y50-70 charging port wires detached from mother board , I have to solder it again but there is no wiring connection indication on motherboard . Anyone can please share how to solder these wires on mother board ? which wire for which point?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
This may help:
http://www.s-manuals.com/notebook/lenovo...
Have you tried taking a high resolution photo of the motherboard or using a magnifying glass or loupe to look closely at the board. You should be able to see where the connections were. A broken wire end or some other disturbance at the solder pad..
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
I checked and came to that charging ics had burnt and I am unable to see ics number as well. Is there anyway to get charging ic numbers?
из
Hi @Muddaser Talal
You should be able to find it if you search through the schematics I pointed to you above.
из
Добавьте свой ответ
Muddaser Talal будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 300
