Представленный 3-его марта 20 17 г. Nintendo Switch- это портативная приставка, способная устанавливаться в док-станцию и выводить картинку на TV
617вопросов Показать все
micro sd card reader not working even after replacement
my micro sd card reader wasnt reading sd cards. so i purchased a replacement and repair kit from this website. followed directions and it still doesnt work idk what could be the issue but nintendo online repair is closed still and im just really annoyed things just cant work.
Это хороший вопрос?
Оценка 6
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Same thing as I had for 2 years, for me it was that you need to make sure the connecter is fully pushed in. If it still doesn’t work it may be a faulty socket on the board (don’t quote me on that).
Был ли этот ответ полезен?
Оценка 2
I was in the same situation. After closer inspection, my socket was bad. I had missing pins. So I had someone replace it for me and it started working again. Replacing the socket requires micro-soldering, beyond my skills.
Оценка 2
1 Комментарий:
I'm in the same situation as you who fixed yours and how much did it cost
из
I am also in the same situation. I did notice that while the switch is on, I can get the switch to detect the replacement reader if I press down on the connector at a certain angle. But I need a more permanent solution. I can’t be playing with the back open like that.
Оценка 0
it is good to you . you search new ways
Оценка 0
Добавьте свой ответ
Luke Priore будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 52
За всё время: 729
