error code 80010514, how do I repair this problem?
I put the game in,it starts to read then stops then wont eject, I have to hold the eject butten for 12 sec to eject the disc!
Это хороший вопрос?
Это хороший вопрос?
Now this is what I have about the error that you are receiving. "The error code is actually one of two things, a) a faulty sector on the internal hard drive, or b) a faulty installation of software/firmware, both iterations actually coincide with each other. If the hard drive suffers a faulty sector ( a section of damaged space on the drive that data may have been written to that no longer is readable), an installation may still be processed, and even work, but the error can cause some serious side effects, such as option b. If your PS3 has installed an item incorrectly, including firmware, it is in high risk of receiving this error." So I guess what you are looking at is corrupt of game disc recognition. Check on this link and see if that will help you getting back in the game. There are also a few videos on Youtube that might help out. Some people have had the error fixed by replacing the BR drive, so you may have to experiment a bit. Good Luck to you.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 25
За всё время: 11,528
