Acer Iconia Tab W500 — это планшет на базе Windows 7 с 10-дюймовым сенсорным экраном и собственной док-станцией с клавиатурой.
Acer Iconia Tab W500 SSD/Ram?
Is there a way to replace the SSD on the Acer Iconia Tab W500 and the Ram? I want to replace the SSD with a 1TB instead of using the 32gb one.
Это хороший вопрос?
Счет 1
3 Комментариев
How do qou flash bios in acer w 500
из
Is it possible to add a second SSD to Iconia Tab W500 internally ?. Has anyone tried it ?.
из
Hi,
What is known RAM?
из
Добавить комментарий
5 Ответов
Наиболее полезный ответ
Acer W500 uses mSATA ssd. Currently you can upgrade it upto 128GB. Regarding RAM, as per C50 processor specification, you can upgrade it upto 4GB but the existing 2GB ram sitting behind the processor and it is soldered to it.
I have upgraded my SSD to 64GB, but I did not upgrade the RAM.
I really enjoy using this tablet.
Был ли этот ответ полезен?
Счет 3
Hi,
The Iconia Tab uses mSATA SSD drive, so is it possible to upgrade SSD to 128-256 GB, but not more because is not available 1TB SSD.
Счет 1
1 Комментарий:
Hi,
Now 1TB mSATA SSD (Samsung 840 EVO) is available. So does Iconia Tab W500 support that 1TB mSATA SSD?. Can any one confirm ?.
Thanks.
из
I recently upgraded my W500 SSD to a Mushkin 240GB mSATA with no issues.
Only requirement was first flashing BIOS with latest version from Acer
Счет 1
I have not found anyone that has torn it apart but you can check the forums at http://forum.tabletpcreview.com/acer/
Счет 0
Works like a charm. Worth the upgade - DO IT !!
Счет 0
Добавьте свой ответ
Juan A Silva Jr буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 14
За последние 30 дней: 45
За всё время: 22,366
