Model A1347 with 2.4 or 2.66 GHz Core 2 Duo Processor.
76вопросов Показать все
Check if SMC was reset
I want to do an SMC reset and did so by powering off, disconnecting cable, holding pwr button, plugging in, powering on. But is there a way to verify i reset the SMC successfully? Resetting PRAM/NVRAM is clear because you hear 2 chimes
Это хороший вопрос?
Оценка 0
2 Комментариев
I'm not sure I follow what you are looking for.
из
When you do the SMC reset, is there a way to know you did it properly? Like, sound cues, reset date/time or something like that. I want to know if i did it properly
из
Добавить комментарий
1 ответ
Выбранное решение
A SMC reset null’s the values it holds so there is no means to tell for sure. What is the problem you think an SMC reset will alter?
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
It was high temps and weird fan controlling. But i think it did reset because the volume changed from max to 50%
из
Добавьте свой ответ
Max Tech будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 8
За всё время: 155
