Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Vertical lines on screen without any connector damage
I was replacing a charger port assembly and when i plugged everything back in there were lines on the screen, so bad you couldnt see anything, however i could tell it was still “on” because vibration worked when i would place a wrong finger on touch id. After cleaning the display connectors with alcohol, very lightly with a brush on both screen and phone, the lines dimmed and the phone was usable but with faint white lines. After being quite stuck i unplugged and plugged in again and it was unusable again, really bad lines, now coloured. I now put the old charging port back into the phone and it has behaved the exact same.
I have tried other screens that are cracked and broken (because its only what i had spare) however they dont show any lines, the only faults show are what was already bad with these other lcd’s. Meaning it must be something with the display correct? I didn’t do anything i don’t do with other phones that i fix fine. When i opened it, i could tell it had been repaired before (missing screws) is that relevant?
Please help, i’m on a time crunch! Thanks!
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Sounds like you need a new screen.
Был ли этот ответ полезен?
Оценка 1
Second @tech_ni's opinion; certainly sounds like time for a new screen.
Any chance you connected/disconnected the screen with the battery still hooked up? That's been known to cause damage to screens.
It could always be a connector issue as well; in this case the fact that other screens work would tend to isolate that cause to the screen's connector and not the motherboard's. Get out the magnifying glass and a bright light and go over the connector and the flex cable looking for bent, broken or missing pins or any kind of damage to the cable itself.
Оценка 1
Добавьте свой ответ
Jack Chadwick будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 214
