The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313вопросов Показать все
Why is my fan running so much?
About two months ago I bought from iFixit Store, and successfully installed, a 1TB Aura SSD upgrade for my 500GB 2014 MacBook Air.
But, annoyingly, the computer's fan now runs almost all the time, even when Activity Monitor registering almost nothing.
If I run "Checking your Mac" I get a message "There may be an issue with a storage device: Reference code VDH002."
Any suggestions for fixing this annoying problem?
Thanks: Gareth W-W
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Did you talk with OWC tech support? I would do that as they may have some knowledge on the issue.
There are a few things I would try. First power down your system and disconnect the battery. Carefully remove the SSD and wipe down the contact area with a cotton swab moist with 85% or better isopropyl alcohol. I would also spray the socket with the isopropyl alcohol using a pump sprayer and so can’ed air.
How much empty space do you have on your drive?
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
wynnwill будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 44
