Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
101вопросов Показать все
Display turns on and off and has colored lines
Our iPad 5 had broken glass but worked fine before the repair. After replacing the battery, and home button assembly, it turns on/off every 5 seconds and the display is only colored lines and bands. Any ideas?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Make sure you disconnect the battery before you do anything. Get a magnifying glass and check the connections and make sure the pins aren't bent if they are ok clean the connectors with a qtip and alcohol and a soft brush.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
John Rogers будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 25
