Is there no inverter cable?
I have this Early 2009 Macook 2.0Ghz Core 2 Duo. I bought it with this problem where the backlight goes off at about 45 degrees and comes back on somewhere at the 120degree angle. I tried to look for parts but I cant find any inverter cables. I know these sometimes break internally and it has happened with one of my older ones, which I did replaced. I cant find the same part for this laptop when I researched it on Ifixit. Does this not have the same cable that the older ones had?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Yes there is an inverter cable for the early 2009 MacBook. It takes the same one that the MacBooks late 2007 Santa Rosa - early 2008 Penryn use ( 3 wall connector on the board). Ifixit does not have any in stock at the moment. Here is a link verifying that the early 2009 MacBook takes the same cable I mentioned. Here is a google shopping search for the part.
Был ли этот ответ полезен?
Оценка 4
Добавьте свой ответ
Zahan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 787
