Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2375вопросов Показать все
Вопрос закрыт
No service, low signal after replacing backplate
I bought a rear plate, i repleaced it carefully as mentioned, but after that, my internet is gone, low signal, or even no service. I put back the original one, but the problem is still on. :( I was very careful.
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
There is an antenna behind that backplate, check if you have damaged it as its very fragile
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
What you mean behind? On the other side of the backplate, or on the iPhone's back? I checked the everything, but everythings seems to be ok, but as i said, i was really careful and not playing any parts of it just changed, but after changed back its still bad:S
из
the service sticker attached to the speaker unit has a small diode that needs to be reconnected.
Оценка 0
1 Комментарий:
reconnected to the motherboard.
из
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 939
