Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
2376вопросов Показать все
Why low WiFi signal, after opening device?
i have opened up my iphone 4 to replace the battery and the front camera, after doing that i started to get very low wifi signals.
anyone else getting this and is there anyway to fix it?
thanks
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Every guide that ifixit has made for the iphone 4 contains a warning about the screws on the motherboard and that damage/dirt or wrong screw will effect your wifi...you also need to check that you haven't lost the little metal piece on the cover. Clean all the greasy fingerprints off. Take a look at the front display guide linked on the right under the photo....go to step 13 &14 for a pictorial guide to what I mean.
Был ли этот ответ полезен?
Оценка 3
3 Комментариев:
i didnt read the little text on the sides.... thanks... how would u recommend cleaning with the windex? using a cloth or papter towel... or anyother way?
из
I didn't use windex( because I don't have it)..used a lint free cloth (like you get for cleaning glasses) it worked fine.
из
oh.. thanks.. i will try to clean all of the things off with that now.. thanks for the help!
из
Добавьте свой ответ
Edwin V будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 1,304
