This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316вопросов Показать все
Green light without screen with a working Wifi card
Hello! I have this DS Lite board. When I turn it on the green light stays on even without the screen. I know this happens when the Wifi card is not connected. But even if I connect it, this happens. The Wifi card is not faulty, tried it on a different board. Where should I look for fault on this board?
https://imgur.com/a/Odw7SK5
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I have a motherboard with a similar issue. Green light comes on when it shouldn't. I found that toggling the power off and on again several times will make the system boot up but it will freeze shortly after booting. I've replaced the wifi board the two screens and the digitizer with known good parts from other units. Nothing seems to help. I have a feeling it may be a bad capacitor somewhere on the board but I don't have the schematic or experience to diagnose this.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Gaboros будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 23
