Released April 2015, also known by model name A10-70F ( 'F' representing that this is a wifi only model)
47вопросов Показать все
How can I fix my charging port?
Everything on my Lenovo tab A2 10 works except the charging port. When I plug in any charger it won’t charge the tablet. When my tablet lost its final charge I couldn’t use it anymore. I know its not the battery because it worked just fine its just charging the tablet was getting progressively harder and I had to angle my chargers in different ways so it could start charging the tablet.
Это хороший вопрос?
Оценка 1
1 Комментарий
Where did you buy replacement charging port ? I saw some generic ones on Ebay.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@sal10 sounds like a bad charging port. It is soldered to the motherboard. Use this guide Lenovo Tab 2 A10-70 Motherboard Replacement to get there. Then you need to remove the old port and solder a new one in. This video has some pretty good directions. The ports are available at places like this
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Salvador будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 18
За всё время: 1,510
