Memory test failure, fix and some questions
Overnight my B590 developed a memory fault.
On boot up, a single long beep, and the machine would drop into the bios. Upon running the inbuilt memory diagnostics, I found that values being written during the test were coming back with a single bit always set to 1.
Did usual reseating of the DIMM, changed the DIMM location, swapped the DIMM with a new module. Same error, indicating that this was probably a motherboard issue.
Ran memtest86 (4 passes) from a USB drive with no errors. On rebooting, Windows started up as usual.
Q1: Why did this work? I can only speculate the memtest somehow cleared the stuck bit on the motherboard. Bad capacitor?
Q2: Is this problem likely to resurface?
Это хороший вопрос?
