The digital camera was released by Panasonic in July of 2016. The Panasonic Lumix DMC-ZS60 has 18-megapixels and wifi mobile device connectivity.
Popping/Cracking Noise when zooming
When the camera is powered on, the lens makes a small cracking noise while extending. Other than that it works normally. How can I fix this?
Thank You!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Andrew Jensen  sounds like you may have some dirt/debris in there. Other than disassembling the lens and trying to clean it, which is a challenge without proper manual, there really is not anything you can do to fix it. Only other thing is to replace the lens Panasonic Lumix DMC-ZS60 Camera Lens Replacement
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Andrew Jensen буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 908
