After cca. 5 minutes F13 error code appears, ventilator buzzing
Hi,
I have a Hotpoint Washer/dryer. Washing works well, but drying stops with F13 code after cca. 5 minutes. The ventilator motor makes a buzzing noise. I think it turns slower, then it should, but can’t see any junk, to slow down it, I can rotate the blades easily. The motor of ventilator looks intact. In spite of that it is the reason of overheating?
Can someone help me?
Update (10/01/2020)
Type is FDD 10761
Это хороший вопрос?
2 Комментариев
New aspect: I connected the ventilator AC motor to the 230 V power network. The motor sometime spined well, then the rotation got slower and slower, then stopped, and after a bit it started to rotate again faster.
I don't know whether these AC motors are drived by frequency converter, or they get the 230V/50Hz power? In case the second option, I think the AC motor is faulty.
из Csaba Katona
I’ve fixed it! :-)
The AC motor was faulty. In the beginning when I tryed to rotate it with my fingers I thought it rotates easily. But, when I get the new motor the new one was spinning so much easier, than the old one.
Since then the drying function works perfectly, no F13 error!
Thanks for every help!
из Csaba Katona
