13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574вопросов Показать все
Does not to boot up, tries
My MacBook won’t boot for hubby, I can’t try my log in because he did a forced shut off & it just comes back to his log in when turned back on. It just sits there looking like it’s booting up but 45 mins later it still in the same spot,
Это хороший вопрос?
Оценка 0
2 Комментариев
Lets do this restart your system and press the D key so your system enters into diagnostic mode. Did it pop any errors?
Reference: Mac startup key combinations
из
Ok I ran the test a second time & was told no issues found. Code ADP 000
из
Добавить комментарий
1 ответ
Выбранное решение
It was that age old problem I had with the old Macs….the PRam. I had it clear 3 times, it’s booting up fine, slow but fine.
Thank you so much for the referral to the codes.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
ladycerridwyn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 4
За всё время: 45
