New Icemaker is not working
I replace the ice maker on my Whirlpool refrigerator model GZ25FSRXYY2 a week ago after the old one would make ice but get stuck in the cycle. The new one has not made any ice and am looking for input. It is the correct ice maker and the wiring harness was replaced as well as part of the process.
Update (10/16/2020)
Thanks for the advice. It appears after doing some more checking that I’m not getting power from the refrigerator harness that connects to the icemaker harness. I’ve checked the ice maker harness for continuity and it all checks good. Any suggestions on what would prevent power not getting from to the refrigerator harness?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Sounds like your problem is electrically based. Here is a link to some troubleshooting tips for icemakers
You will need (1) a short piece of insulated wiring to activate the icemaker motor test and (2) a multimeter for the other tests. These tests require the 110 current to be on so be careful with these live test points under the controller cover.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Brian будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 113
