I installed new memory but still get 3 beeps
I installed new memory & still get 3 beeps, have tried to reseat a few times, still same result. I did carefully vacuum inside, could I have damaged the logic board? The Mac was previously getting some lines on monitor Occasionally . Logic board was replaced 4 years ago. Thanks
Это хороший вопрос?
2 Комментариев
Are you sure you have the correct RAM?
Reference: MacBook Pro: How to remove or install memory
Does an external display show the same lines? If not then the internal display will need to be replaced.
из Dan
Thanks Dan, yes I have the correct ram. I will try with an external monitor once I get it going.
из robert.monty
