The Volvo XC90 is a mid-size luxury crossover SUV manufactured by Volvo since 2002 and now is in its second generation.
16вопросов Показать все
Why is my SUV chugging in idle?
My SUV keeps chugging when coming to a stop and idling. It is fine while I’m driving. The rpm gauge jumps up and down slightly in idle as well. I was told to use Mystery Motor Oil. Any suggestions? Thanks.
Это хороший вопрос?
Оценка 0
2 Комментариев
Any engine light or codes? Sometimes the coil packs get wonky and only work when the cpu asks for higher rpms. Used to own many volvos and fixed them regularly.
из
@caleymac what exact year and engine size is your Volvo? Besides "Mystery Motor Oil, what have you tried? How is your gas mileage? Has it gone up drastically? How is the performance when not at idle?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Rough idling can be caused by clogged filters. ... Bad spark plugs, bad spark plug wires and a bad distributor cap are other common causes of rough idling. These items are all important parts of what keeps a vehicle running. Spark plugs provide the spark that ignites the air and fuel mixture within the cylinders.
Был ли этот ответ полезен?
Оценка 1
It’s the throttle body dirty I had mine like that even at a stop sign shuts off . Took it off and cleaned it with throttle body cleaner from autozone now it idles like brand new
xC90 2006
Оценка 0
1 Комментарий:
That makes sense. It wouldn't trip a code either.
из
Добавьте свой ответ
CaleyMac будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 742
