The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
151вопросов Показать все
Full screen static after display replacement
Anyone seen this before? It’s new to me.
The entire screen is scrambled gray and rapidly flashes about half of the screen as shown in the screenshot from a video I took. This is the second display from the same vendor that I’ve installed in this ipad and both produce this static-like image. If I re-install the broken LCD, I can see the image clearly (as clear as possible on a broken display). There are no signs of static on the original.
I’m concerned that I’ve received two defective replacement panels, but it feels unlikely. Again, I’ve never seen this behavior before in a replacement panel.
Any ideas or thoughts? Thanks!
Edit: I forgot to mention that I did see one similar post from searching and they were successful by performing a DFU reset. I went ahead and tried it, but the issue persists.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Apparently, I cannot read. The LCD panel I was using as a replacement was for A1823 and I’m working on an A1893. Whoops!
Был ли этот ответ полезен?
Оценка 0
When you close the screen use a cloth to remove static but this may not resolve the issue if the LCD you got is broken.
Оценка 0
Добавьте свой ответ
Christopher Stout будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 173
