The Razer Kishi is a universal mobile gaming controller that fits most smartphone devices, designed to bring console-level control to your on-the-go gaming. It was released in June, 2020.
11вопросов Показать все
What is the ribbon cable pin count?
I want to hack this controller for a 8 inch wide tablet, but the existing ribbon cable assures I cannot do it stock. The rubber flex back strap and spring combo (versus telescoping hard plastic) gives me hope that if I get a longer ribbon cable, I could also fashion a longer strap. I can't tell from the photos of it's a 14 or 15 pin. Also, what is the current length of the ribbon cable so I can figure out the size I will need for my tablet? Please inform. Thanks!
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi Jacob, I disassembled the Kishi again and counted. There are 14 pins and the pitch is 0.5 mm. Here is closeup for you.
Был ли этот ответ полезен?
Оценка 3
Based on this close-up, it looks like 14 pins: https://d3nevzfk7ii3be.cloudfront.net/ig...
Unsure what the pitch is, though. I’m considering attempting the same mod myself.
Оценка 2
Добавьте свой ответ
Jacob Schmugge будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 34
За всё время: 1,544
