2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
265вопросов Показать все
MacBook Pro A1398 No backlight
hello, so the macbok does not have a backlight, it works fine via HDMI.
i have checked the board and found a blown fuse, replaced it and its still the same,
i have checked the LVDS cable and i can see that pin 1 and 2 on the retina screen connector are damaged..
can this cause the backlight not to work??
Это хороший вопрос?
Оценка 0
1 Комментарий
i have replaced the connector on the display and it works now, thanks!!
из
Добавить комментарий
1 ответ
Выбранное решение
Clearly you’ve got a messed up T-CON board within the display assembly!
Here’s a snippet of your display connector. FYI: Its miss-marked as LVDS the connection is technically iDP
It might be a bad connector or the T-CON board its self. Its very easy to damage the panel and the T-CON board. Best to just replace the full display assembly.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Hello, thanks for the answer, I was looking for this schematic everywhere!
из
Добавьте свой ответ
jozef horvath будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 23
За всё время: 287
