Released February 2018. Dell Inspiron 14-5482 features a 14.0" HD screen and Intel i7 core.
6вопросов Показать все
The fan is really noisy.
The fan has been noisy in this machine for quite some time, and seems to get worse over time. When I say noisy, I don’t mean that it is running at high speeds. It just doesn’t sound right when it runs, even at low speed. It almost sounds like it has a bad bearing. I’ve opened up the machine and everything looks clean, and the fan blades look good. I’m not sure what to do. Can I replace the fan? Should I?
Это хороший вопрос?
Оценка 1
1 Комментарий
The repair is complete! I highly recommend https://www.parts-people.com/
из
Добавить комментарий
1 ответ
Выбранное решение
TYLER GOODWIN  absolutely should you go ahead and replace the fan. If it is noisey it is most likely a bearing and to keep it running like that may lead to overheating from an ineffective fan. This site will show you exactly how to replace it.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
TYLER GOODWIN будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 6
За последние 30 дней: 43
За всё время: 704
