Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
broke the "small antenna" during battery change procedure
During the battery change procedure, which went well for the most part, I broke the “small antenna cable” identified in section 17. Didn’t notice until reassembly. Since it is not the GPS nor the WI-FI antenna, I’m unclear exactly what I will find inoperative once I finish. Is a replacement available? (I was confused by the difference in picture between the Wi-Fi model and mine. Oh well.)
Это хороший вопрос?
Оценка 0
2 Комментариев
I’ve never used the Cellular capabilities of the mini 2, so will I miss anything if I do nothing? Will the mini constantly remind me that the antenna is broken? Note: I bought the cellular version to get the improved GPS capabilities.
I’m off now to get some 90% isopropyl to clean the gunk left behind from the glue.
из
I don't believe so.
из
Добавить комментарий
Ответов (1)
Выбранное решение
It is the Right Cellular Antenna. With a damaged antenna, you will have less (or no) cellular sugnal.
Replace a right cellular antenna compatible with the model A1454, A1455, A1490 1st or 2nd generation iPad mini tablet. Изображение
Продукт
iPad mini & mini 2 Right Cellular Antenna
$9.99
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Leon будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 79
