Do I need to melt the adhesive before attempting to remove the back?
Various videos online show people just prying the back of the phone off with a spudger. I assumed I would need to use a heat gun or iopener or something similar to melt the adhesive first? Just want to make sure I do this right
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
I’d highly recommend it, since it not only makes the separation of the screen easier, but also prevents the breaking of the screen an other components from using too much force.
Word of caution: Whether you use a heat gun or a hair dryer, keep the heat moving along the edges and not stationary on one spot, as it can cause damage to the screen and other parts of the phone. If you have an iOpener, place it for a few seconds on the edges of the device every few seconds. This also should help opening the device with more ease.
Hope that helps.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
WRONG! Please see Smilzos answer, next. Thank you Smilzos. * I too have sought a guide, and for some time.
из
hello, it does not require a heat gun, the back is only interlocking. I just wrote a guide if you want to check. regards
https://it.ifixit.com/Guida/Huawei+P+Sma...
Оценка 1
1 Комментарий:
из
Добавьте свой ответ
Tobey B будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 16
За всё время: 1,442
